More Tubes And Collars..
发表于 2021-9-1 00:31:59 | 显示全部楼层 |阅读模式
Got 8 tubes to weld the collars into the head..Collar and Head..Then the head into the tubes..The depth of the stop for the head was a little deep as you can see..So it was impossible to get the tungestion "down there" to do the welding untill a slight modification to the tungestion was done..Notice the "hook"..Try it sometime for those next to impossible angles..I JUST LOVE IT!! when everything comes out nice and even.. welding aroung corners is not impossible..Bend the tungestion and give it a try!!I get all the fun jobs.....zap!Last edited by zapster; 05-08-2007 at 03:50 PM.I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:very nice work zap,at least one person learned something.
Reply:How'd you do the bend? Grind it in? or heat and push?How does the bent end affect the arc and the gas flow?
Reply:Originally Posted by enlpckHow'd you do the bend? Grind it in? or heat and push?How does the bent end affect the arc and the gas flow?
Reply:Great technique! Thanks for the tip and great job as usual...My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:And I thought I had seen everything. Nice
Reply:That is some amazing stuff right there! I like the bending of the tungsten. Wild.
Reply:Pushing the tungsten into the copper must not contaminate it? I'll give that a try. Super welds.
GMT+8, 2025-12-21 22:03 , Processed in 0.105004 second(s), 18 queries .
