Guesstimates on axle rating...
发表于 2021-9-1 00:31:58 | 显示全部楼层 |阅读模式
I just "inherited" a solid steel (not one of those cheapo galvanized ones) boat trailer.  The boat that came with it was a 16' Javelin fish and ski with 110HP engine.  I am thinking about converting it into a utility trailer.  Problem is, I can't find any ratings on the axle.  Any educated guesses out there?Thanks!
Reply:Originally Posted by wicrulesI just "inherited" a solid steel (not one of those cheapo galvanized ones) boat trailer.  The boat that came with it was a 16' Javelin fish and ski with 110HP engine.  I am thinking about converting it into a utility trailer.  Problem is, I can't find any ratings on the axle.  Any educated guesses out there?Thanks!
Reply:If you can tell us the size of the bearings in the hub then I can probably tell you.  My guess off the top of my head would be a 3500 lb axle if it is a single axle trailer.  ~JacksonI'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:It is a single-axle trailer.  I will have to get the measurements this weekend.
GMT+8, 2025-12-21 22:03 , Processed in 0.094047 second(s), 18 queries .
