learning to weld
发表于 2021-9-1 00:31:47 | 显示全部楼层 |阅读模式
Hi I was wondering if I could get so pointer on my weld these is my third time using a mig welder. Sorry if the pic look crappy I got a very cheap digtal camera.I used a Hf 151 mig welder with .030 wire with argon mix.But I just bought a lincoln weld pak 175 to try out with in the next week I got it new for $100 new in the box. A friend at work bought a better one before he even open the box for ths one.Peter Attached Images
Reply:No comment untill better pics are posted.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Welcome to Weldingweb new_welder! As Zap stated, in a 'round about way, your pics are very blurry and it's tough to see. However blurry, your one bead looks cold and very concave...and messy. When welding, remember that clean metal is mean metal. Grind it down, wipe it down, wire brush it and then wipe it down again. After that, practice making beads almost like your trying to draw a long line with a crayon very slowly. Practice this in cirlces, Z pattern and U pattern. Give it a shot and post back with some good pics. Thanks for sharing.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:You actually got a couple of short sections that look OK, maybe 1/2" long, so I'm guessing your weld settings may be close to OK.The rest is pretty messy, some weld on one leg, none on the other.Don't know what you did to create this but here are some guesses.1.  If something is causing the wire feed to hang up momentarily, (like a dirty or kinked liner, spatter covered worn out contact tip, or loose drive wheels), the arc length will become excessive as the wire burns back toward the contact tip, and this lack of wire feed and long arc will give an erratic weld.2.  Moving the gun at an erratic speed, or making large changes in tip to work distance, could cause this also.
Reply:In addition to the above... clean that metal first !***************************************Lincoln AC225 stick welderLincoln HD100 WeldPak flux core wire feed welderThree of the cheapest grinders money can buy
Reply:Keep the the gun steady.  Brace your self, be slow and consistant.DavidReal world weldin.  When I grow up I want to be a tig weldor.
GMT+8, 2025-12-21 22:32 , Processed in 0.072076 second(s), 18 queries .
