Dirking around with ParkerMP 160
发表于 2021-9-1 00:31:45 | 显示全部楼层 |阅读模式
I bought this little tig/stick/plasma combo last month and havent used it very much.  Decided I would run it a bit today and see how it held up when its leaned on.  Been a while since I have run an air cooled torch, that booger gets hot fast.  Alot of times I will run the hose across the back of my neck like a "boa", but I gave up on that quick.  Few pics below.  Nothing special, 3/8" mild steel strap, offset outside corners.  The top two are multi pass MS filler, the bottom two are messing around with building up a pool of 309S.Last edited by brandon75173; 05-18-2007 at 09:29 PM.Lots of toys.
Reply:nice weave super clean63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
Reply:Originally Posted by usmcgremlinnice weave super clean
GMT+8, 2025-12-21 22:29 , Processed in 0.093508 second(s), 18 queries .
