查看: 2|回复: 0
90 degree help
发表于 2021-9-1 00:31:40 | 显示全部楼层 |阅读模式
ok laugh if you want but i need to put a a 90 with out cutting 45 in a piece of 1x 2  tubing. well i dont have a bender and i was wondering if yall had any ideas .
Reply:dang it has 17 views and no one can give an idea. wtf ....lol .... i figured on filling with sand and heating it, but was hoping on other ideas from people with more "aint got what i need when out in the field" experience to give other solutions. so give me the best or the dumbest idea you might have.
Reply:I'd say we need more info.  Why can't you cut 45s?  What radius bend are you looking for?  Wall thickness?My name's not Jim....
Reply:I agree with boost. Need more info. You stated not cutting 45 degree. Should I assume you don't want to cut but bend. If can cut but not 45 degree, cope it. If bending with out bender, as stated by Assassin, fill with sand cap ends and heat........Anyone know how to put the little raised 0 when typing a degree?Miller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
Reply:Originally Posted by waginI agree with boost. Need more info. You stated not cutting 45 degree. Should I assume you don't want to cut but bend. If can cut but not 45 degree, cope it. If bending with out bender, as stated by Assassin, fill with sand cap ends and heat........Anyone know how to put the little raised 0 when typing a degree?
Reply:90º is done with ALT 167.  Hold down ALT, and type 167.  See the chart at the bottom of the following URL (Extended ASCII Codes):http://www.asciitable.com/The Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:wall thickness is 1/8 radius i would say 4in on center and i don't want to cut 90 cause i don't want the sharp corners but if i have to its no big deal.
Reply:ALT ºHoly @#$%^&*it works
Reply:That's a fairly tight radiusº. Sand pack with heatº( tight) and heatº evenly. Orº, cut kerfs out (three sides, leaving the outside faceº of the bend uncutº), bend and welded up the º kerfs. ºBlatant abuse of new toyº...........¿....oooo® .....Ohñ....ahh200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:i cant make the degree symbol to work lol
Reply:I can't get it to work, either.Nctox,  Stickmate LX  235AC/160DC  HH210
Reply:Originally Posted by assassin_worksi cant make the degree symbol to work lol
Reply:I would make the 45° cuts, and then use the same chop saw to cut the corner off the outside edge.  You could even weld it into the inside elbow when you're done, and have a 90° corner with less-acute transitions.Some vendors sell ready-made curved sections of round tubing, but I'm guessing yours is square.(° is easy on a Mac computer -- opt-shift-8.)Jack OlsenMy garage website
Reply:You have to use the numbers on the keypad (right side) not the ones at the top - RyanLincoln Weld-Pak 140HDHypertherm Powermax 30HF 4x6 bandsawHF 21gal compressorCraftsman Commercial drill press4.5" Craftsman Professional angle grinder4.5" HF angle grinderOld benchtop table saw with a cutoff wheel and sawzall
Reply:90º90º 5t works that is awsome but i got a net book so it is a pain in the *** to do ill stick with * lol
Reply:Originally Posted by Jack OlsenI would make the 45° cuts, and then use the same chop saw to cut the corner off the outside edge.  You could even weld it into the inside elbow when you're done, and have a 90° corner with less-acute transitions.Some vendors sell ready-made curved sections of round tubing, but I'm guessing yours is square.(° is easy on a Mac computer -- opt-shift-8.)
Reply:do a 4 piece 90  ...................... number of degrees in bendangle of cut= --------------------------------------....................... number of welds x2
Reply:You can either make a few smaller mitered cuts, or you can buy pre-bent pieces of tube.  I dont have a supplier in mind, but I know you can find them.You really dont have any other choice.Have we all gone mad?
Reply:Originally Posted by assassin_worksyes its rectangular and if i cut kurfs out how many and wide and far apart would i need to make the 90
Reply:Post deleted - Had a different way to type the ° but it is not needed.Last edited by Black Wolf; 06-02-2010 at 01:13 AM.Later,Jason
GMT+8, 2025-12-21 22:31 , Processed in 0.089059 second(s), 18 queries .
