Tig....
发表于 2021-9-1 00:31:37 | 显示全部楼层 |阅读模式
Well here is something I have never posted....... an example of my TIG welding. So here it is..... I had to Tig a tapper lock onto both ends of a steel roller.I used the positioner for this.One side....The other end....Thanks for looking......_________________Chris
Reply:Nice tie-off!!..Great! How many of those exist anyway??? ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Beuatiful!Real world weldin.  When I grow up I want to be a tig weldor.
Reply:And I had just noticed that the bushings are in line with each other.. Cool that you can see to the other side.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Its all shiney (grin)..  thanks for sharing lorenzo.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:Looks great! Man, I need a positioner !! John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Wow, that looks really good!  A lot better than anything I lay down.
Reply:Originally Posted by zapsterAnd I had just noticed that the bushings are in line with each other.. Cool that you can see to the other side.. ...zap!
Reply:Awesome looking Lorenzo. I see it says Dodge on it; it it from a Dodge truck?
Reply:Purdy Chris, What's it for?DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Originally Posted by yellowFrom my "untrained" and "uncalibrated" eyes I actually see that they are not lined up. Pics 6 and 8 from the top show that the milled areas are not lined up on both sides. Perhaps I am looking at the wrong thing but its starting to bug me now. Can you clear up what I am supposed to look for Zap or lorenzo?
Reply:Great job Chris,  Nice looking tig welds. Hope all is well.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:Sorry to beat the bush any longer but for my own personal knowledge; in pic 8 the frontmost bushing has its threaded keyway at around the 6 o' clock position while the rearmost bushing has its keyway at around 4 o'clock. Are you saying that a single threaded key passes through both of these bushings and they are lined up? The same can be said for pic 6. The front bushing "seems" to be at 12 o' clock and the rear at 10. I've seen the common notched keyways but this is my first time seeing a threaded one. Sorry for the hijack, just trying to add something new to my mental database.
Reply:If you put the bushings into the weld in bushings (its a 2 piece set for each end) you'd see that the keyways are lined up on each end with each other..Thats where your "missing the boat" as to say.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Ok when I get home I'll post pics of what these look like without being installed and you'll see why they look like they are not in line when they really are..I found some new ones in the shop.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
GMT+8, 2025-12-21 22:30 , Processed in 0.293084 second(s), 18 queries .
