Project Stop
发表于 2021-9-1 00:31:36 | 显示全部楼层 |阅读模式
Is your welding table /  welder cart rolling around and you don't want it too? Here is a simple fix, without buying locking casters. I used 1/2 square tubing (fence picket drops), that I get out of the scrap bin. A fun project for newbies setting up a new shop.
Reply:They start here Attached Images
Reply:Finish out and in action. These work great, I mount my bender on the table, and since it has 4 pivot wheels, I use 4 stops. Lean on it hard as you want and it doesn't move. Nudge them out with your toe, to wheel it anywhere you need to.You can paint them any color to make them easy to find. Attached Images
Reply:So simple, so smart.  I'm gonna make some of those!
Reply:What kind of bender do you have?
Reply:HF special. It works for me (so far) Attached Images
GMT+8, 2025-12-21 22:32 , Processed in 0.068819 second(s), 18 queries .
