Coal bucket conversion project
发表于 2021-9-1 00:31:35 | 显示全部楼层 |阅读模式
This was a coal hauling trailer we are converting into a scrap steel hauler. We are lining it with 1/4" AR plate provided by the customer. The shedder plates(the turned up sides) were bent up by cutting 12" and leaving 3", cutting 12" and leaving 3", and so on.The first picture is obviously looking straight into the trailer. The box you see at the end is the "jack box" it houses the hydraulic cylinder.We will be bolting the steel into the original aluminum bed. I will post more pictures as this job progresses.  Thanks for looking.
Reply:Well lets go!!Get to work.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
GMT+8, 2025-12-21 22:31 , Processed in 0.109942 second(s), 18 queries .
