Need info about my forney welder
发表于 2021-9-1 00:31:32 | 显示全部楼层 |阅读模式
I have this welder and would like some info about it. I am going to sell it because i got a 220 wire feed and don't need the arc welder. Does any one know how old it is? How much should I ask for it? Any info would be great. Thanks Attached Images
Reply:OLD!--Just kinda kiddingLooks to be in great condition,but you'll probably be lucky to get anything over $150 out of it probably less. Depends on your area...who might be looking for one..leads/length...extra stuff... Unless you just gotta sell it...It can do things that wire welder can't...like heavy stuff with ease.You're call...
Reply:Just like Mudbugone said it can do things the wire feed welder can not do. And a 100 dollars would be a high price to get from the sell of it, and I don't understand why because mine welds so smooth. I couldn't imagine getting rid of mine. Look in my posts and you can see mine (not as pretty as yours) but a hellaofa welder!And you can go to Forneys web sit and get a manual for it download PDF file, its a combo file ie. has your model and a couple with similar functions. So the info you get so far says, keep it you wont be sorry you did. Oh and it looks like a late 50's model.Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
Reply:Keep the stick machine.  I recently got rid of an old Forney AC machine and used the $$ to help purchase a Lincoln 180 wire feed machine.  I quickly found out that the Forney machine had capabilities that the wire feed did not.  I wish I had held onto the stick machine.  It was old but still ran fine and did a good job.  It was worth more "in hand" than I sold it for
Reply:Keep it,  againUA Local 598
GMT+8, 2025-12-21 23:46 , Processed in 0.091513 second(s), 18 queries .
