mig or stick for a trailer?
发表于 2021-9-1 00:31:29 | 显示全部楼层 |阅读模式
i need to weld a crack on a flatbed trailer(for a big rig) and im wondering if its ok to use mig? i feel a lot more confident with mig then stick. My plan was to grind out the crack a bit, fill it in, then plate over it. So would mig be alright?
Reply:If you grind it back and maybe bevel it to ensure 100% penetration all the way through you will be alright.UA Local 598
Reply:I'd say there's no where near enough info given to make many suggestions at all. What size mig? What sort of skill level do you have to be considering making major structural repairs of this sort on a vehicle? We are not talking about some small ATV trailer but one that could carry loads that weigh in excess of 30 ton's. Do you have any clue what the frame is made of, heat treated steel. psi rating on the frame, correct weld perameters and so on?Not to bust on you, but a question this basic kind of makes me think that if you have to ask, then it's probably not a job for you to be doing yourself. Over the road vehicles are a bad place to learn as you earn.Last edited by DSW; 06-05-2010 at 08:57 PM..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:id find some literature on the composition of the steel and the coded procedure for welding it. thats pretty serious.lincoln weld pak 100 hdlincoln ranger 225gxt ac/dcoxy/acetylenepuroxcw202 victor fc100harris model 85harrismodel 16oxweld w24roxweld w17
Reply:if its easily welded steel id bevel,6011root,7018fill,and u never said where it was on the bed.is it under a compressive or tensile load and how much of one at that.lincoln weld pak 100 hdlincoln ranger 225gxt ac/dcoxy/acetylenepuroxcw202 victor fc100harris model 85harrismodel 16oxweld w24roxweld w17
GMT+8, 2025-12-21 22:31 , Processed in 0.067146 second(s), 18 queries .
