Got a huge problem on a 653 tank repair
发表于 2021-9-1 00:31:20 | 显示全部楼层 |阅读模式
i HAVE A 1018 OLD SHELL PLATE AND WELDING A36 TO IT.  i AM GETTING BALLS OF A TAR LIKE MATTER IN THE ROOT.  i AM GETTING SOME ARC BLOW.  I HAVE HAD THE STEEL TESTED FOR CONTAMINATES AND NOTHING SHOWS UP....IF I KNEW HOW TO PUT THE PICTURE UP ON HERE I WOULD...ANY IDEAS
Reply:Here is a pic Attached Images
Reply:looks like trapped slag...Need to clean(grind) mating surfaces...What porcess-filler-etc...?Miller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
Reply:Your going to have to include much more information than that if you want  a good reponse.Process?Filler?Joint prep?  CAC by the looks of it but I could be wrong. Single/double bevel?This tar substance shows up after the root pass is laid in?  During?  Before?Have we all gone mad?
Reply:Got it figured out....nothing like magnatism....the tar is flux and the rest is slack caused from arc blow.....
GMT+8, 2025-12-21 22:30 , Processed in 0.099655 second(s), 18 queries .
