Lincoln Idealarc 400 R3-S delima ...
发表于 2021-9-1 00:31:19 | 显示全部楼层 |阅读模式
Got a Lincoln Idealarc 400 R3-S that I purchased to get the dolly. Idealarc 400 is three phase and most folks want single phase 220. problems is scrap copper is $3 lb.. making scrap value higher than welder is worth. Idealarc weights 475+ lbs, easily 250 lb+ copper or $750+ in copper value. sure hate to scrap this out... but I'm running out of room. 52, 59 & 66 Lincoln SA200, Tombstone Idealarc 250, Thermal Dynamics Cutmaster 50, Marquette 250 amp mig, Miller 330 A/BP
Reply:Shame to scrap such a good quality industrial welding powersource. Those 3 phase Idealarc's were very good industrial welders.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:here's the entire set-up with LN-7 Wirefeed with Tweeco mig gunprobably will use LN-7 with my XMT 304 ... that or sell wirefeed separately. just busted down the wirefeed support cables today. ya... sure hate to cut it up.....52, 59 & 66 Lincoln SA200, Tombstone Idealarc 250, Thermal Dynamics Cutmaster 50, Marquette 250 amp mig, Miller 330 A/BP
Reply:_CY_ - I'm afraid you may be overestimating the machine's copper content.Let's have a look inside.Don't forget some welder transformers are aluminum wound, even large industrial units, although this one probably isn't aluminum.Odd that the welder seems to have a single-phase cord end. Good LuckLast edited by denrep; 06-01-2010 at 12:51 AM.
Reply:hmmmm single phase cord end?... just checked ... it's definitely a four wire 3 phase plugLast edited by _CY_; 06-01-2010 at 01:20 AM.52, 59 & 66 Lincoln SA200, Tombstone Idealarc 250, Thermal Dynamics Cutmaster 50, Marquette 250 amp mig, Miller 330 A/BP
Reply:It'll have some copper hardware and other smaller coils, but I kind of wonder if the total would even hit 75# with very labor intensive separating.Good Luck
Reply:My guess is a very generous 100# but I wouldn't be surprised if you're right denrep.  Most of that transformer weight is the steel core.  Same goes for slope coils/stabilizers and then there's the steel frame of the unit etc.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:thanks... looks like with that little copper... this idealarc is saved from the scrap heap. the copper leads to wirefeed was 40lbs alone  Originally Posted by denrepIt'll have some copper hardware and other smaller coils, but I kind of wonder if the total would even hit 75# with very labor intensive separating.Good Luck
Reply:What's your location? I'm in Manning, SC, and while I don't really need another machine I'd hate to see such potential go to waste.
Reply:thanks much for all the concern... sold it yesterday for $400 including LN-7 wirefeeder and tweeco gun off craigslist to an experienced welder. was soooooo glad Idealarc 400 will live to see another day.52, 59 & 66 Lincoln SA200, Tombstone Idealarc 250, Thermal Dynamics Cutmaster 50, Marquette 250 amp mig, Miller 330 A/BP
GMT+8, 2025-12-21 22:31 , Processed in 0.098193 second(s), 18 queries .
