valve body
发表于 2021-9-1 00:31:13 | 显示全部楼层 |阅读模式
Interesting fabrication made up from custom formed one inch plate.  For those who like thicker stuff Attached Images
Reply:Sweet.  It looks like a butterfly or flap check valve. Do you know if will have a motor operated actuator (MOV)?Hobart 140 Handler w/ gasHyperTherm Powermax 380 Plasmaoxy/acetylene
Reply:A big handle of some sort ... that's all.  It is for a dredge.  Likely taking lots of water and river mud/sand.
Reply:The little guy setting on the valve----he's the inspector??
Reply:fluxcore or dual-shield? what parameters?are you welding it?My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:Originally Posted by SandyThe little guy setting on the valve----he's the inspector??
Reply:His name is Victor and appears when there are any ratty cuts around.
Reply:That's not a valve body, it's a heavy duty torch holder.  Check the flange on the right side.
Reply:That would be funDewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Valve body? I thought that was the fuel shut off for Zaps drag car! "Every choice you make will effect at least one other person"
Reply:thats a fun looking project , what helmet is that there it looks identical to the boc or cig ones we get here in australia
Reply:Wow,   First thing I thought was how much does that beast weigh?Come try it out and stay a while.
Reply:Originally Posted by sam -ozthats a fun looking project , what helmet is that there it looks identical to the boc or cig ones we get here in australia
GMT+8, 2025-12-21 22:29 , Processed in 0.266964 second(s), 18 queries .
