W186 procedure
发表于 2021-9-1 00:31:10 | 显示全部楼层 |阅读模式
I'm looking for a description for the W186 "" welding of reinforcing Bars in rienforced Concret constructon""I'm looking for wire and gas or stick type to use. I googled it with no results beside company that want to sell you a program.
Reply:try lincoln website or other rod manufacturer?
Reply:If it's anything like the AWS requirements, your electrode type is dependent on what grade of rebar you're welding.
Reply:Originally Posted by SupeIf it's anything like the AWS requirements, your electrode type is dependent on what grade of rebar you're welding.
Reply:Originally Posted by weldbeadtry lincoln website or other rod manufacturer?
GMT+8, 2025-12-21 22:31 , Processed in 0.088140 second(s), 18 queries .
