Refilling Tanks Cost
发表于 2021-9-1 00:31:09 | 显示全部楼层 |阅读模式
How much should I pay to refill a 4ft argon tank?How much to refill 5ft 75/25 argon/co2 tank?How about a acetylene 'B' tank?This is the first time I will be refilling all three of them.I will be going to a small privately owned welding supply place not AIRGAS.I am in Las VegasThanks in advance.Last edited by lectrician1; 05-02-2010 at 06:39 PM.Reason: LO
Reply:Price vary by location but you might be looking at $40 for ea of the three.
Reply:Thanks. I went to Praxair once and they quoted me $160 for CO2
Reply:Originally Posted by lectrician1How much should I pay to refill a 4ft argon tank?How much to refill 5ft 75/25 argon/co2 tank?How about a acetylene 'B' tank?This is the first time I will be refilling all three of them.I will be going to a small privately owned welding supply place not AIRGAS.I am in Las VegasThanks in advance.
Reply:$46 bucks here for a 330 large Argon/CO2 82/18.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:$24 for a 125cf of 84Ar/16co2If you cannot convince them, confuse them.         Harry S Truman
Reply:170$ to fill a 280cf argon mix lasvegas
Reply:$30 for a 300cuft 75/25CWI, CWE, CST for Miller, Lincoln, Thermadyne, Hypertherm & ESABMillermatic 350PLincoln Invertec 205 AC/DCVictor combo torchESAB PCM 1125
Reply:$60 for a "T" (the biggest) 75/25 or 100% Ar"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Just paid $52 for 150cf 100% Argon at Praxair in LV.
Reply:Do you have an account with them?I just called airgas, nevada compressed gas and was  46-52 for a 80cf. VegasWare is that praxair in vegas
Reply:No account. The location i went to was right around the corner from Curtis Steel. I think on thompson rd.
Reply:I miss Vegas, Grew up on Ann Rd / 95Centennial High class of '011981 Lincoln SA 200Miller Trailblazer 302gMiller 211 Mig Welder w/ AutosetI'm learning to stick metal together
GMT+8, 2025-12-21 22:33 , Processed in 0.091169 second(s), 18 queries .
