Ideas on building reels
发表于 2021-9-1 00:31:07 | 显示全部楼层 |阅读模式
I have been searching for the last 3 hrs and have yet to find out how to build a set of reels. I have found a bunch of pictures and know how to isolate the stinger, but how should I build the spool shaft? Use bearings of some types? I attached a picture of some reels, does anyone know how the shaft and bearings are designed on them? Attached Images
Reply:You might get away without using any bearings.  It's not like these are high speed, or carry a lot of load.  I might be tempted to just use round stock for the shaft, just drill a hole in the center of your end plates, and call it done.  The reel will run steel-on-steel and may wear a little, but it'll take years to wear out.  If I didn't have the proper drill bit, I'd probably drill it a little undersized, then use a die grinder to open the hole so it fits well to the shaft.  Not too sloppy, not too tight.Seeing as how those are cantilevered out, you may want a fairly big diameter shaft.  In that case I'd probably use pipe instead of solid and use a hole saw instead of the drill.  You might even torch cut the hole and clean it up with the die grinder.Dynasty200DX w/coolmate1MM210MM VintageESAB miniarc161ltsLincoln AC225Victor O/A, Smith AW1ACutmaster 81IR 2475N7.5FPRage3Jancy USA1019" SBAEAD-200LE
GMT+8, 2025-12-21 22:31 , Processed in 0.074836 second(s), 18 queries .
