Well...here it is...I was tired of rethreading the little spools for the machine with my 15 lb spool so I decided to make a new cart for storing my baby in my room and adapt the big spool to the frame.It has to be small so I can maneuver inside the house till my room, so here it is...The feeder seems to work fine...as you can see its a 3/4 nut welded to the base and the bolt has a 7/8 tube welded to it, I wondered if metal to metal would cause enough friction to stop the spool from unrolling, so I had some 10 ga. electric wire and give some turns to the tube for increased friction, seems to work out fine. No critics on the welds, I made this so fast I couldn´t weld correctly, my dad is waiting for his grill and some parts are just tacked...ohh, hopefully the welder won´t move much so I can take it outside to weld inside my Baja (if I ever get to own a bug), well gotta plan for the future!Any coincidence with the gravity racer, it´s not mere coincidence!Enjoy Attached ImagesMy Babies: HF Drill pressHF Pipe Bender3 4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:2.................................. Attached ImagesMy Babies: HF Drill pressHF Pipe Bender3 4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:on the nut the HORRIBLE weld was a fill up weld... I actually filled about a .5" rectangular space! Attached ImagesMy Babies: HF Drill pressHF Pipe Bender3 4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:last one! cant wait to get some paint, and some front wheels too! Attached ImagesLast edited by elvergon; 06-08-2007 at 03:31 AM.My Babies: HF Drill pressHF Pipe Bender3 4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:good looking job there mate im sure it will do the job great
Reply:Thanks man I read your post about welding it directly to the back of the welder...It looked pretty thin for me to weld over it, and peeling too many paint off would be a pain :SI also needed the cylinder portability so the cart was a better ideaPretty nice idea the one of welding it in the back thou!thanks for the comment!My Babies: HF Drill pressHF Pipe Bender3 4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:thats ok , elvergon , we mostly use ours just as a standby machine ad when we have to go somewhere to weld parts so the bottle just gets dragged along with it and sat next to the machine , one thing you might want to do as we did with ours was made up a cover for the wire out of some canvas to stop dirt and moisture settling on the wire while your using it we just made it civer the spool and has a hole in it for the wore to come out of . it isnt nessecary but a good investment if your working outside in the elements .
Reply:FInishedPainted with rustoleum hammered finish paint. Pretty nice and can says it works great in the worst working conditions, lets see... Attached ImagesMy Babies: HF Drill pressHF Pipe Bender3 4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:you can see the a little bigger than 1/2" hole...It doesn´t has any protection for the wire, I need to see if it gets to hit the walls...if so I´ll put something of nylamid over there... Attached ImagesMy Babies: HF Drill pressHF Pipe Bender3 4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:No more threading of little spools and I get to sleep with my baby next to me...HELL YEAHH (it won´t sit on the living room anymore) Attached ImagesMy Babies: HF Drill pressHF Pipe Bender3 4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:You might be a welding addict if you....sleep with your welder next to you "Every choice you make will effect at least one other person"
Reply:Yeah...tonight is my first day...I tried the cart today too...works perfectly, easy to move, no wire feeding problems and I can get it to my room in about 20 secs Couldn´t be better My Babies: HF Drill pressHF Pipe Bender3 4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:Looks great man. How does the taller bottle hold up on your base? I was hoping to skin the base of my cart but if just cross supports work then I will try that.Come try it out and stay a while.
Reply:well here they are 1.25" thick each, so it gives very nice support, I´ll try these they work great. Good luck!My Babies: HF Drill pressHF Pipe Bender3 4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it! |
