Anti Spatter Primer
发表于 2021-9-1 00:30:59 | 显示全部楼层 |阅读模式
Is there any anti spatter primer available in the market?
Reply:Are you using a water based brush on type anti spatter? If so, clean with soap and water or soap based cleaner first.Matt
Reply:There is spray on anti spatter availible. We use it at work. It's made by weldcote. Just like a can of spray paint.
GMT+8, 2025-12-21 23:46 , Processed in 0.093620 second(s), 18 queries .
