more updates on my recumbent
发表于 2021-9-1 00:30:50 | 显示全部楼层 |阅读模式
More photos - check out the handlebar stem that I cut up and re-welded so that I can clamp a vertical handlebar thingy in it:http://i203.photobucket.com/albums/a...t_overview.jpghttp://i203.photobucket.com/albums/a...d_steering.jpghttp://i203.photobucket.com/albums/a...r/seatpost.jpghttp://i203.photobucket.com/albums/a...lder/stem4.jpghttp://i203.photobucket.com/albums/a...lder/stem3.jpghttp://i203.photobucket.com/albums/a...lder/stem2.jpghttp://i203.photobucket.com/albums/a...lder/stem1.jpg-  John Attached Images
Reply:(1st pic)That thing looks like articulating way to the orthopedic surgeon's office!! I like it!!!And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:[QUOTE=runchman]More photos - check out the handlebar stem that I cut up and re-welded so that I can clamp a vertical handlebar thingy in it:Comin' right along... am looking forward to hearing how you like the new ride.  Thanks for the pics.
Reply:Everything is looking good..... I do like that every flat surface in your shop has burn marks on it (ie: the wooden stool in the background)Thanks for sharing the projectPeople are more violently opposed to fur than leather because it's safer to harass rich women than motorcycle gangs.  Unknown Pro Mig 175Hyphertherm 600Lots of toys at work
Reply:Originally Posted by dangthatshotEverything is looking good..... I do like that every flat surface in your shop has burn marks on it (ie: the wooden stool in the background)Thanks for sharing the project
GMT+8, 2025-12-21 23:38 , Processed in 0.105639 second(s), 18 queries .
