A small garden gate I made years ago.
发表于 2021-9-1 00:30:50 | 显示全部楼层 |阅读模式
This gate was made of materials and ideas from other jobs.  The cala lily (flower) was made for a balcony I did 5 years ago.  This was the first one I made.  It is formed from 1/16" sheet that was heated and shaped.  The stem is 1/2 inch round bar.  The butterfly body is 1/2" round shaped with a grinder.  The wings are 1/8" sheet, I don't remember how I cut them.  The antennae were made from 1/16" o/a welding rod.  The welding was done with o/a.The pickets are 3/4 inch 16g tubing.  The spears were formed by running a cutoff wheel down the center of the tubing about 2 inch deep.  The halves are then hammered together.  Then the process is repeated until the point is formed.  The gap is welded and grinded/ground.  I got this technique from making bicycles.  It is a method for taperng stays(smaller tubing on a bicycle) to fit wheel dropouts.The sun is torch cut from 1/8" sheet.  It was left rough.  The latch is 1/2" sq. inside a 3/4" tubing.  Perhaps this might stir somebodies creative juices.  I had no use for this gate.  After It was built I drove around with it welded to my truck and took it to some landscape designers as advertisment. Attached Images
Reply:cool stuff! lots of talent. "Every choice you make will effect at least one other person"
GMT+8, 2025-12-21 23:49 , Processed in 0.097179 second(s), 18 queries .
