need advive on buying a torch set used :/
发表于 2021-9-1 00:30:46 | 显示全部楼层 |阅读模式
http://smd.craigslist.org/tls/1805024274.htmlim buying a torch set. tell me what you think about it. anything i should know from your experences.also what should i look for when buying them. year? markings? anything? to see if there good that is.Thanks alot
Reply:Originally Posted by moneymaker17http://smd.craigslist.org/tls/1805024274.htmlim buying a torch set. tell me what you think about it. anything i should know from your experences.also what should i look for when buying them. year? markings? anything? to see if there good that is.Thanks alot
Reply:Originally Posted by makoman1860Looks like one of the many victor portable setups ( or at least sold by them ). Victor J series handle ( probably a 28 ) and some small regulators. Im guessing its from the late 1980's , hard to tell the condition from the pictures. If you want a portable setup its probably not a bad price if its all in good condition, if the regulators creep or the torch valves dont seal its going to get expensive quick. A new equivelant setup is about $350-450. Also understand the limitations of the cylinder size, portables are great for safe cracking and quick small jobs, but are expensive to feed and have serious limitations on cutting use and larger welding tips.
Reply:1-despite the 1/7 rule, when using a typical welding tip for an aircraft size torch, the portable tanks seem to last about 4 hours, much less while cutting.2-honestly about 3/8 with that cylinder size3-Of course, but your going to be limited to about 1/8"-3/16" thickness due to cylinder size.4-depends how much you want to use it, you can always start on it, and if the cylinders are getting used up too quickly, get ( or rent ) larger cylinders and transfer your torch over.
Reply:one more question. how can i check and see if the hoses and guages are good and not leaking etc.etc.etc.????
Reply:spray everythiong with soapy water solution..if it bubbles theres yer leak
Reply:Unless you really need the portability of that tiny rig, you would be much better off buying one of the myriad of full size shop rigs I see for sale regularly on my local Craig's List.  $300 can buy you a good full sized rig with extra tips, hoses, cart, larger regs, full size torch, etc that will be much better for shop use.  If your purpose is to keep it on the truck and use for small portable jobs on site, the small set may be right up your alley.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Originally Posted by DesertRider33Unless you really need the portability of that tiny rig, you would be much better off buying one of the myriad of full size shop rigs I see for sale regularly on my local Craig's List.  $300 can buy you a good full sized rig with extra tips, hoses, cart, larger regs, full size torch, etc that will be much better for shop use.  If your purpose is to keep it on the truck and use for small portable jobs on site, the small set may be right up your alley.
Reply:These set are for small jobs.  Mainly used in the HVAC industry.  You will be very limited in what you can do.  Also, the cylinders look old, oxygen tanks have to be hydrostatic test every 5 or 10 years.  It may be expensive to get the oxygen filled.To test for leaks, pressurize the system with the torch valves closed.  If either high pressure gauges goes down, you have a leak some where.  Use the soapy water to find it.  If either of low pressure gauges goes up, the valve seat in your regulator are leaking and the regulator will have to be rebuilt.  If they need to be rebuilt, you should not pay more than 45.00 per regulator.  Some repair shops may offer a discount for multi peice orders.  I know we do.Hope this helps.JImOAdoctorwww.regulatortorchrepair.com
GMT+8, 2025-12-21 23:41 , Processed in 0.073457 second(s), 18 queries .
