Welding related.. Somewhat
发表于 2021-9-1 00:30:43 | 显示全部楼层 |阅读模式
I have a young co-worker that decided to wire in his amps, so he found the first heavy wire laying around and did an awsome hillbilly job on it.  It's 600v 2/0  Welding wire.Common sense in an uncommon degree is what the world calls wisdom.
Reply:I'd like to be there when it wears thru and shorts out...  ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:EeeeHhhhaawwww!!!Real world weldin.  When I grow up I want to be a tig weldor.
Reply:That's awesome!
Reply:He'd better not do that - -If he squeezes it too tight, he'll cut down on his power John-----------------------------------|Craftsman 230/140 amp AC/DC BuzzboxSynchrowave 250
Reply:Originally Posted by Brainfarthand did an awsome hillbilly job on it.
Reply:Is that what we call a "power window"?  John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Must be one of those effeminate hillbillies - he made sure the cable matches the paint color of his vehicle.
Reply:May not be all that welding related right now but once that insulation is gone his hood or door should be fused quite well. Should get him to wrap it in a tig rod so it'll be stronger.My Photos on Flickr
Reply:the wife got a laugh out of that one!  63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
Reply:Originally Posted by zapsterI'd like to be there when it wears thru and shorts out...  ...zap!
Reply:That's our DA of the day.  LOLDewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:NICE! Hey what part of Oregon are you from?Millermatic 211 with 150 spool gunDynasty 350 Hypertherm powermax 30XP
Reply:I'm in the new nappa vally(carlton, oregon), that's where I get most of my s.s. work from.   He's been driving that truck around for 2 weeks now, as it is.  I'll mention to him that the plastic flux on the cable may give him porosity.Last edited by Brainfarth; 06-25-2007 at 12:40 PM.Common sense in an uncommon degree is what the world calls wisdom.
GMT+8, 2025-12-21 23:49 , Processed in 0.095309 second(s), 18 queries .
