Atv Log Skidder
发表于 2021-9-1 00:30:42 | 显示全部楼层 |阅读模式
ATV log skidder to be towed behind atv to get logs out of the bush and to a landing or to your portable saw mill with very minimal amounts of sand on firewood log or saw log,only about 6 inches or less drags on ground,not only is there little to no sand to worry about but there isn't much drag on bike because most of the log is up off the ground.Bike should tow unit with no effort at all. Hook chain around log,pull pin on front of skidder,raise the log lifting bar in the upwards position,hook chain into grab hook on arm and then easily and with minimal effort lower arm and repin it and your log is up off the ground and free from snagging any other debris or stumps on your way out of the bush and off you go to the destination in which you would like your log to be placed.Very easy setup and no lifting by hand, no mechanical parts to wear or break,no winch cable to keep trying to get unjammed.Comes with 6foot skidding chain with hooks.1200Lb load capacity. I just built to sell and to see if there is any market for this type of unit.I am looking forward from getting some input from all the welders and memebers on this site as to weather or not that this may be a good idea to make and sell,or even if there would be a demand for such a peice of equipment like this.Last edited by MicroZone; 06-24-2007 at 10:14 PM.
Reply:looks like that should get the job done!  my only concern would be the tires not being wide enough and might sink.  or might pop due to the weight bouncing on them coming out of the woods. other than that nice job!63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
Reply:Sorta like a "timberjack" on wheels..I just wrap a chain around the tree and drag it out with the truck..But I like the concept..Better patten it before someone else does... ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Looks good.  What is the weight capacity  of the tires?    Maybe you could sell it to the guy thats going to cut down 70' trees with a garden tractor. Nice idea, it should sell.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:1200Lb capacity
Reply:being from south louisiana we get a lot of rain like i said eariler wider tires for this neck of the woods.  I still like the setup. way to go!63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
Reply:people will buy anything for the right price!
Reply:Ya better patten it soon  DavidReal world weldin.  When I grow up I want to be a tig weldor.
GMT+8, 2025-12-21 23:48 , Processed in 0.070245 second(s), 18 queries .
