Its been awhile...
发表于 2021-9-1 00:30:42 | 显示全部楼层 |阅读模式
4130 Air BoxI first put grind marks in a straight line before welding the air box. When all said and done It got powder coated clear the pics shown are in raw form.Strive For Perfection
Reply:looks good what type of vehicle is it going in?63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
Reply:O.... It goes on a quad 250R with a dirt bike motor in it..Strive For Perfection
Reply:thoose are some pretty darn good looking welds. what did you use? looks like a "tap tap tap(sipps coffe) tap tap tap..." weld
Reply:A truly professional job.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Originally Posted by The ~noob~ Riddikthoose are some pretty darn good looking welds. what did you use? looks like a "tap tap tap(sipps coffe) tap tap tap..." weld
Reply:That thing is awesome. Very nice looking welds.Miller Syncrowave 200Hobart Handler 140Thermal Dynamics Cutmaster 38E-Z Tube BenderPlasma Cam DHC2
Reply:Another outstanding job Brooks.You and I have to meet up sometime and have a beer.  - Paulhttp://all-a-cart.comWelding Cart Kits and accessories
Reply:Niceeeeeeeee!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Very nice work. totally professionalMiller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:Very professional box Brooks. Hobart 140 Handler w/ gasHyperTherm Powermax 380 Plasmaoxy/acetylene
Reply:Good stuff, do you have to back purge the Chromoly?John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Looks like a good weld day.  Nice work.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Originally Posted by ZTFabAnother outstanding job Brooks.You and I have to meet up sometime and have a beer.  - Paul
Reply:Originally Posted by MicroZoneGood stuff, do you have to back purge the Chromoly?
Reply:Thanks for the complement's GUYSStrive For Perfection
GMT+8, 2025-12-21 23:50 , Processed in 0.094705 second(s), 18 queries .
