removable compact bender mount pictorial
发表于 2021-9-1 00:30:42 | 显示全部楼层 |阅读模式
here's what i came up with for mounting your compact bender so it can be removed when not in use. first you want mark out where you want it then take a 5/8 drill bit and mark your holes then once that's done and your sure everything is centered drill 1 inch holes. after that done get some half inch by 6 inch j bolts take 2 nuts and weld them together then round them enough to fit snug in some 3/4 EMT weld them in then grind them flat  then take a cutting disc and put a series of notches on your EMT. with that done clean them and your holes in the concrete next get some anchor bolt epoxy this stuff is strong so don't get it everywhere. anyways you may have some movement in the holes so you will need to cover the bottom of your bender with tape with that done epoxy the bolts in then sit your bender over the holes and insert the bolts for a minute to center all the holes then carefully remove the bolts and bender and wait for it to cure once that's done make your handles out of the j bolts and you have a removable mount 350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:for some reason it shows from finish to start ohwell you get the idea350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:You should also get some flush screw heads to put in when not in use so you don't fill the bolts with crap.My Photos on Flickr
Reply:i forgot to add that you could throw some screws in there or put some rubber plugs350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:I'm ambidextrous...Start to finish...Finish to start..Whats the diffrence?Nice boj!.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Were the notches to provide a better surface for the epoxy to bond to? How big were they?Thanks
Reply:Originally Posted by toweldWere the notches to provide a better surface for the epoxy to bond to? How big were they?Thanks
Reply:Great idea and perfect timing, I should be getting my model 3 bender delivered in the next couple of days and was thinking about how to mount it to the floor...thanksSure, I can fix it... I got a welder!!!
Reply:Originally Posted by umahunteryou got it lemme explain this type of epoxy is used with a threaded rod to bolt a wall to a foundation so you will have much better grab by giving it something to lock onto like on a bolt instead of just the smooth pipe
GMT+8, 2025-12-21 23:49 , Processed in 0.187731 second(s), 18 queries .
