Memorial Plaque
发表于 2021-9-1 00:30:40 | 显示全部楼层 |阅读模式
This is the 16"x16"x0.75" Mild Steel Plate that I started with.  The penny is for size reference.This is after the plate was cut and the mill scale was ground off the top.  The edges were left rough for a more "natural" look.I wrote the letters with a sharpie and then traced them with the torch and no wire so that they would show up while I was welding.I welded the letters at the top and the leaves with Silicon Bronze and the vine and the rest of the letters with stainless.I used a O/A torch to give the metal some color
Reply:nice work WW.63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
Reply:So the finished plaque was coated with clear laquer but there were several problems.  The first problem is that the laquer removed the color from the metal.  The second problem was that instead of clear laquer, the can held black laquer and we ended up spraying the black on the top of the heart.  Well, I actually liked the way it looked so we lightly sprayed the edges to give it kind of an aged look.
Reply:Thanks Gremlin
Reply:i am glad u took another pic i was having trouble making out the words .....nice little saying........ is that going to be put on a wall or somthing63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
Reply:Nice! You have a steady hand! I can't even write that neat with a pen and paper.Lincoln AC/DC 225/125 Stick Linde HDA-300 MillerMatic DVI MIG Miller Dynasty 200DX Hypertherm Powermax 1000
Reply:Taking a good pic of this plaque is near impossible with the shiny steel and the multiple layers of laquer.  All light wants to reflect, making it impossible to capture a good image.  The plaque is going to be put into a garden.  I don't think that it would be possible to hang on a wall because it weight about 40lbsFor those of you having trouble reading the saying:Sue & CarlIf our tears could build a stairwayand our memories a lane, we wouldwalk right up to Heavenand bring you home again
Reply:Awesome!DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:very cool. MelShould last a very long time made of steel.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:weldrwomn, what kind of laquer are you using? I am assuming it is for rust resistance, right?Lincoln AC/DC 225/125 Stick Linde HDA-300 MillerMatic DVI MIG Miller Dynasty 200DX Hypertherm Powermax 1000
Reply:Carl, I am using Rustoleum Clear Laquer.  With several coats all around (plus the mill scale was left on the bottom) I hope that it will provide rust resistance.  I am going to tell my Aunt and Uncle to re-apply the laquer once a year.  Even if they let it rust, only the base metal will rust.  The stainless lettering and the bronze should be rust-resistant and stand out from the mild steel.  This plaque is a replacement for an engraved slate stone.  The slate was beautiful, but it cracked after a couple of years.  I don't think that the 3/4" steel will crack anytime soon...lol
Reply:Very nice.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:Wow, that is immaculate, the best memorial I've seen in some time.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Very impressive WeldrWomn.I need to make a grave marker for sister in-law.  And you just gave me a great idea.  I was going to try and cast one in bronze.  But I like your idea better.  Thanks a million for sharing.Thanks Again!!LarryMTry not use $10.00 worth of time on $.10 job!!Miller Bobcat
Reply:have you considerd a set of legs to hold it up a little at a slight angel to alow the water to run off?? some thing like 3" in the back and 1" in the front. just enough to alow for run off. then you could replace the legs as needed and the plaque would last for ever. maybee make the legs more of a platform then legs so it just sits on it. it heavy enough its noyt going to blow away.looks great though. you put a lot of work into it and it shows. summer is here, plant a tree for mother earth. if you dont have time or space, sponcer some one else to plant one for you.feel free to shoot me a PM or e-mail me at [email][email protected] i got lots of time.
Reply:Awesome!  ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:wow thats coolChuckASME Pressure Vessel welder
Reply:Very Nice!!John-----------------------------------|Craftsman 230/140 amp AC/DC BuzzboxSynchrowave 250
Reply:That's awesome WW.
Reply:It's been said already, but I'm saying it again..........AWESOME!!When the  drops the  stops!Check out my website at:  Tombstone 180 ACHandler 120Millermatic 210Powermax 380Harris & Victor torchesSawzallChop Saw
Reply:Thanks for all of the nice complements everybody!  They are much appreciated!!!
Reply:sweet nice job350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:The complements are well deserved..... nice job!_________________Chris
Reply:Excellent job WW.   It looks great.Come try it out and stay a while.
Reply:Nice, Awesome work, and welds look pretty cool specially the ones of the leaves...that´s a great piece of art...and the leg stuff seems that could work pretty nicely...I love women who can weld!My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!Nice work. like it alot
Reply:Beautiful tribute, and it will last a very, very long time!Cudos,  from a Newb WW
GMT+8, 2025-12-22 01:19 , Processed in 0.110739 second(s), 18 queries .
