My new Intake...
发表于 2021-9-1 00:30:40 | 显示全部楼层 |阅读模式
My new Intake finally almost completed... i used 3.5 aluminum so i could utilize the 3.5 maf ive had lying around here...an i integrated it right into the tube..with out using big ugly couplings....i will use this to hook up my Maf translator to control fuel an timing...old intake...Last edited by Krypto; 06-13-2007 at 11:07 PM.
Reply:Quality....nice welds overall.  Backpurged or no?
Reply:nice welds and slick move with the MAF. you should consider adding a velocity stack, i've seen good things.with full intent and better sense to recognize what is false and part with it.
Reply:Nice clean look...how thick is the Al?you might need Micro´s help...a turbo would fit great in there!My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:looks goodDewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Nice job.  Looks really good.Favorite right now is a Miller Syncro 200.Tons of tools and I blame at least one of them when things don't go right.
Reply:Looks good. So, you welded the pipe right onto the MAF...hmm, interesting. Thanks elvergon...In my opinion...everyone needs a turbo. John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:not that i'm an expert, or really know much about this, but what happens if you have to replace the MAF??
Reply:The Maf body splits..an the plastic sensor comes out...which is how i welded it..because it would have melted the o-rings an sensor..no back purge..Ive built a complete turbo setup in my head..but doing so would require some money..an on the other hand the 3800 tannys are just fragile..atleast for my wallet... i just wanna make some decent power on grandpas Buick Riviera...as a sleeper.. its a series 2 SC with the lil M90 blower...runs about 10lbs of boost with the pulley...i just need some timing an fuel control for right now.
Reply:Very nice setup, people would/DO pay big bucks for something like that!
Reply:nice work
GMT+8, 2025-12-21 23:48 , Processed in 0.109441 second(s), 18 queries .
