How far with a 10 guage cord?
发表于 2021-9-1 00:30:38 | 显示全部楼层 |阅读模式
I have to do some welding on the far side of the house on a trailer. I am wondering how far can i go with the 10 guage extension cord before I start to see asignifcant voltage drop.   Thanks
Reply:Using this calculatorhttp://www.nooutage.com/vdrop.htmIt shows a 10% voltage  drop at 30 amps for 200' of 10ga stranded circuit (includes both "to" and "from" wires - ie. as in an extension cord) at 86F temperature in the open air (wire is not in a conduit). As I understsand it 10% drop should be OK w/most machines; but you should check you manual for exact requirements.Rufus
Reply:What kind of machine, what voltage does it require, how many amps does it pull and what are you welding?  What is your service voltage?MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:its a lincoln 225 ac/dc, 220 coming out. Welding will take place around 85 amps DC. Its going to be welding brackets onto a travel trailer to mount stabilizer jacks to.
GMT+8, 2025-12-21 23:48 , Processed in 0.086439 second(s), 18 queries .
