How To "Grab" Something You Can't "Grab"..
发表于 2021-9-1 00:30:32 | 显示全部楼层 |阅读模式
Where there is a will there is a way..Got a few of these to rebuild The bad journal on..Small (18" O.A.L. 5" rubber diameter) rubber rollers..I could not get the bearing off the other side and we all know what will happen if I grab the bearing in the 3 jaw chuck on the positioner...Ok..Time to "cheat".. 3 3/8" dia round pins 3/4" long is all you need..Put one jaw @ 6:00 and put a pin on it and balance the journal on it untill you get the outer 2 pins in place...You get the idea...Jeesh!Look at how worn out this is!!!!!Well it will wait untill tomorrow for welding...Its only 106 degrees in the shop and I'm going home...So I'll do it first thing in the A.M.I can't wait... ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Zap,Where's the dime!! Just Kidding.The 3/8" x3/4" pins should be enough reference.                                    MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Nice..............   Just curious, why not just cut the bearing off?  Won't they replace it anyway before installing the roller?  Not doubting you, I know you have your reasons, just curious.   ~JacksonI'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:Originally Posted by Hammack_WeldingNice..............   Just curious, why not just cut the bearing off?  Won't they replace it anyway before installing the roller?  Not doubting you, I know you have your reasons, just curious.   ~Jackson
Reply:Zap,after a second look at the pics,is that worn part of the shaft just the inner race of the old brg?                                MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:That's great idea Zap.  If I may improve on it tig weld 3/8 stubs to inside of a flat iron ring so you don't have to hold them by hand.  You could wrap cable tie around the chuck jaws to hold everything while you tighten up chuck each time.LarryTry not use $10.00 worth of time on $.10 job!!Miller Bobcat
Reply:Originally Posted by mla2ofusZap,after a second look at the pics,is that worn part of the shaft just the inner race of the old brg?                                Mike
Reply:nah, that's just the chuck of the positioner...
Reply:Originally Posted by TEKThats what it looked like to me,too. And I hope youre not doing the turn to size with those 3/8 pins holding it like that. That thing will jump out of there and eat you alive.
Reply:It's not the RPM, it's the torque load...the first pin comes out like a bullet. When press operators have to chuck something like that up they'll do similar but use rectangular blocks with a relief (half moon) cut in one end. That gives you full contact on both ends of it and it also can't "rock" and unload and shoot out.Anything worth doing is worth doing RIGHT
Reply:No need to worry anymore..The job is done and long gone by now.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I'm still a little scared...That aint heat lightning in the neighborhood tonight...
Reply:I was like...."what tha... hope he runs slow speeds on the lathe!"well 8 seem ok =)My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
GMT+8, 2025-12-21 23:50 , Processed in 0.369595 second(s), 18 queries .
