Funky Two Step Journal Repair..
发表于 2021-9-1 00:30:31 | 显示全部楼层 |阅读模式
Have 2 Rubber covered rollers to repair..I could'nt get the end too hot so the rubber would melt..Hmmmmmm.......What to do....Here's the worn shaft..Here's the bearing thats going back on..Thats way too much to fill with weld..So here's what we're gonna do..Just weld as "normal" and make it all nice nice..Put it in the lathe and turn the new bushing step..OK...Now I have to go down front and make a bushing..Back in a few.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I hate the other lathes... After 20 min. heres the new bushing...005 shrink fit so heat it up!!Now heres a little trick for you..The bearing landing is .900 wide..So make the bushing .700 wide..Install in the middle of the landing...And now you have .100 to fill in on each side so when you finish turn it you won't turn all the weld off..Now weld it...Now finish it!The new bearing surface is .0015 bigger so the bearing will "tap" on with a light hammer...I gave the journal where the key is the "once over" with the welder just so I know everything runs true after..And we do not have to re-cut the key either..I get all the fun jobs...(And this only took 2 posts......)...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:But, where's the dime????   Interesting optical interference banding in the pic of the plain bushing.  You didn't have to skim cut the keyway at all?Nice job as usual Zap.
Reply:You didn't have to skim cut the keyway at all?
Reply:Nice work Zap.SimonLabel EverythingMetal Fabrication - Welding Repairs - Wrought Iron - Sign Writing - Custom Decals.
Reply:Nice work zap, as always.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:Yep, nice work as usual, sure wish I'd learned the machining end of the deal at some point in time.Anything worth doing is worth doing RIGHT
Reply:Originally Posted by olddadYep, nice work as usual, sure wish I'd learned the machining end of the deal at some point in time.
Reply:Great job, you have both ends to do, right? That's why you get all the fun jobs!John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:looks good like normal Zap!63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
Reply:Good thread.  Thanks for sharing all the details, too.Nice pics as usual.
Reply:Nice work Zap.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:I don't see the rubber on the roller. It is hard for me to sometimes visualize what is going on. Looks like a great job.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:This kind of rings a bell.  I remember reading about sleeving journals that could not be welded up as usual because of some reason I can't remember (something to do with how they were heat treated maybe?).Anyway, shear genius as usual. Favorite right now is a Miller Syncro 200.Tons of tools and I blame at least one of them when things don't go right.
Reply:SOowhat happened to the ruber? :PNice work zAP!My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:I wish I had a big lathe to do that kind of work. Then again I wish I had room for a big lathe. Great job.
GMT+8, 2025-12-21 23:50 , Processed in 0.096296 second(s), 18 queries .
