Mini Bike Build
发表于 2021-9-1 00:30:30 | 显示全部楼层 |阅读模式
Ok, here is a 2 dimensional mock up of my of the classic style mini bike I am building. You would think something like this would be easy, but getting all of the angles right without wasting material is a pain. So far so good, maybe a total of 1' of wasted steel tube, and thats from angling the ends of the tubing with the chop saw. Attached ImagesMiller Syncrowave 200Hobart Handler 140Thermal Dynamics Cutmaster 38E-Z Tube BenderPlasma Cam DHC2
Reply:Need some plans of an 1975 Ruttman I have and old cataloge which has the dimensions in it. Ill try to scan it and post them.Will   Supports Autism Awareness                            My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:I was going to build one too.Then I came across a dealer in Phoenix that carries the Manco mini-bike.I purchased the Streaker for $595, it comes complete and assembled.  It has a 4.0 HP Subaru "Robin" engine.I'm happy with it, maybe you can check out manco and see what you think.KRS***************************************Lincoln AC225 stick welderLincoln HD100 WeldPak flux core wire feed welderThree of the cheapest grinders money can buy
Reply:are you using tav or clutch? what´s your budget for this thing?My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:Tavs are nice I had one on a mini chopper I built. I also have a manco bike its pretty old but well built and reliable.Will   Supports Autism Awareness                            My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:Heres some picture of some of my toys I had.A trail 70 I restored.The mini chopper I built. And a ruttman Grasshopper a buddy and I restored.Will   Supports Autism Awareness                            My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:Nice bikes. I am probably going to use a TAV 2 for the clutch, and the 6.5 tecumseh motor that is pretty much standard yard kart/mini bike equipment. I got a few ideas off of the www.vintageprojects.com website. There are so many different styles out there that its pretty much whatever suits you.Miller Syncrowave 200Hobart Handler 140Thermal Dynamics Cutmaster 38E-Z Tube BenderPlasma Cam DHC2
GMT+8, 2025-12-21 23:48 , Processed in 0.099348 second(s), 18 queries .
