Material Handler
发表于 2021-9-1 00:30:29 | 显示全部楼层 |阅读模式
Okay, I don't know what this thing is actually called, but it used  move material(dirt, and rock), that is brought up out of a 600' shaft , into a muck bin. The completed pictures, assembled and painted will be posted on Monday or Tuesday. I'm going to attempt to explain each part and its function.Picture 1-the main deck that the cart will ride on. The cart rides on the 2x2 square stock, and the deck itself rides between rollers on the 2x2 angle weld on the top and the underside. Pics of the under side in next post.Picture 2-close up of the angle riding on the rollers.Picture 3-This is the frame tha the deck set in, there is two of them, one is shorter than the other.Picture 4-This is the deck in the support framesPicture 5- The underside of the cart that will ride on the 2x2 square stock on the deck.New post will show more pictures.
Reply:These are pictures of the hydraulic cyl. mount. And the underside of the deck, turn uo on its side for welding.these are different views of the the assembly in mock up to do some final adjustments on the unitHope you enjoy these. I will try to post the finished pictures on Monday night. Thanks for looking. FYI- everything was MIG welded Settings were around 27 Amps and 98/2 gas at around 25. Attached Images
Reply:that is awesome, nice work.man i wish i had a shop like that at my disposal.... "Ask not for whom the bone bones, it bones for thee" - Bender
GMT+8, 2025-12-21 23:48 , Processed in 0.089906 second(s), 18 queries .
