Pick my Caster
发表于 2021-9-1 00:30:23 | 显示全部楼层 |阅读模式
I need casters for a welding table/work bench.  Can you give me ideas for something in the1,000 lb range for an inexpensive price?  Lowes largest casters were only rated for around 330 lbs.Thanks
Reply:Inexpensive = harbor freightnearby = maybe tractor supply1981 Lincoln SA 200Miller Trailblazer 302gMiller 211 Mig Welder w/ AutosetI'm learning to stick metal together
Reply:I'm going to assume you mean 1,000 lbs total. If so, then the 330 lb casters will work fine. If not does this mean your table will weigh 2 tons??                                          MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Try  http://surpluscenter.com.  They will have what you need.HTP 2400, HTP 131 TIG, O/A and a ton of fab and mechanics tools.
Reply:I plan on making the table approximately 4x6 with 2x2 square tubing.  I will probably put a 3/8" top on it.  I estimate the table will weigh between 500-1000 lbs.  I don't plan on putting an additional 1000 lbs on top of the table, but I also don't want to build a nice work bench/table and have the casters fail.  Your thoughts?
Reply:Where you gettin' the steel?My Local Steel shop carries casters in that rating- if yours does not stock them I bet they know who does in yer neck of the woods.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:You probably want to look at casters with urethane wheels or steel/iron wheels. Plastic and rubber ones have a nasty tendency to get flat spots just sitting with a heavy load on them, even if they are used within their rated capacity.MSC, Graingers, Mcmaster Carr are good place to look for heavy industrial casters. Enco may also have them..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Are you going to have a 2ton table?  If not, and you table is going to weigh 1000 lbs total then your 330 casters are more than enough.  4x330=1320Have we all gone mad?
Reply:983=over> Hey thanks for posting that surplus place I've been searching for some hydraulic stuff for a project at some reasonable $$$  and they might just fit the bill.  Cheapest wheels anywhere... from an abandoned shopping cart... not perfect but price is very reasonableenjoyLincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:When I recently built a rack for holding rolls of paper ~1,500lbs a pop i went with these casters from northern tool (they are 1,000lb casters and the rack was built from 3x3x.25" tubing).  I have been quite satisfied with them and at $13 a pop they were pretty nice.http://www.northerntool.com/shop/too...ct_40250_40250
Reply:Northern Tools own brand of steel casters. Cheapest I've found and good qualityCut an MGB and widened 11" C4 Corvette suspension and LT1 Chevrolet power & 6 spd. Pictures here:Part 1http://forum.britishv8.org/read.php?13,7581Part 2http://forum.britishv8.org/read.php?13,22422
Reply:I like mcmaster-carr. They have quick shipping, usually same day, even if I order as late as 5 pm. Most of their stuff is good american made.http://www.mcmaster.com/#casters/=7sgoem
Reply:1,000 lb bench, get at least a 5" caster made of steel. will roll easy and stand up. just bought a set from a local specialty caster shop. Oxford caster, rated 800 lb each, roll like a dream and were about 18 bucks each. when you dont want the thing rolling while you are workin just slip some 1/8 flat stocks under the wheels to chock them, works pretty good, I use them on my saw that is caster mounted."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Tractor supply has nice steel castors.Dave ReberWadsworth Ohio
GMT+8, 2025-12-21 23:52 , Processed in 0.081951 second(s), 18 queries .
