my ? is for butt joint with back up strip. I'm in vertical position i can't lay my root in good b/c my rod keeps burning to one side or the other. Anybody with some advice or a trick that would be some help pls post. Thanks!
Reply:I'm going to guess you have some arc blow going on there. Try placing your ground in a different position, or wrap the ground cable around the post holding the fixture.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
