Second welding project: Gas Turbine Engine
发表于 2021-9-1 00:30:18 | 显示全部楼层 |阅读模式
I am building a gas turbine that I will hopefully mount on a riding lawnmower,or one of those three wheeled bikes for old ladies. The point is to build a motor with 100lbs of thrust, complete with an afterburner, and put it on the last thing that you would expect to sound like an f16. Here are some pics of the start of the engine build. It will take a couple of months of free time just to complete the engine. 10hrs so far.Last edited by MicroZone; 07-15-2007 at 12:40 PM. You only need to be 2% smarter than what you are working on.Lincoln pm140hacksawa big hammer
Reply:Looking good so far. Call me biased but I like the turbo. John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:How did you get the pics to post like that? Thanks You only need to be 2% smarter than what you are working on.Lincoln pm140hacksawa big hammer
Reply:Ancient computer wizard-ry trick.  Once you attached, hit the paper clip again, at the bottom of the drop down is "select all" and it inserts all your pics.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by MicroZoneAncient computer wizard-ry trick.  Once you attached, hit the paper clip again, at the bottom of the drop down is "select all" and it inserts all your pics.
Reply:Can't wait to see more!
Reply:Originally Posted by iWeasel410Can't wait to see more!
Reply:I'll wait for the movie... ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by mwccwiYeah, me too - especially to see if it actually works
Reply:Originally Posted by Joe HOf course it will work! Thousands have been built the same way.Looking good so far! You've got a good start on it. I've built several pulsejets, been meaning to build a GT something like your project, but haven't gotten around to anything but reading every available piece of info so far.From what I understand, 100lbs of thrust is pretty optimistic though. A big diesel turbo with afterburner, tuned to perfection, will usually only put out around 75. You should also do everything possible to lighten the lawnmower, and make it roll easier. From my pulsejet experience I know that even 100lbs of thrust would have a hard time pushing most mowers. Expect a slow start, with acceleration increasing as you gain speed. Your top speed should be higher than you want to go on a mower though. I had my big squarestern canoe doing over 30mph with a 50lb thrust valveless pulsejet. If you haven't already, you should check out the yahoo group "DIY gas turbines". There is hundreds of pages of info there, basically everything you could ever want to know.Good luck!
GMT+8, 2025-12-21 23:49 , Processed in 0.103839 second(s), 18 queries .
