Let's See Your Ceiling Crane!
发表于 2021-9-1 00:30:18 | 显示全部楼层 |阅读模式
We call it a hoist...MAC 702 wanted to see the "crane"..So naturally I took some pics...They are "Budgit Hoists"..Rated for 2 tons..But we have picked up considerably more with them.. These are pics of the one "out back" where I am..Hoist..Hook..Travel wheels...Same unit "down front"..So...What do you use yo pick up heavy stuff??No back pics...OK??   ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:This is the only shot of this hoist that I have. Used it for most of ten yrs and its still hangin'. I personally picked 2400 lbs with it. Spooky---  Attached Images
Reply:Mine's not that heavy duty but I use it all the time for moving projects and tools on and off the welding table and just moving stuff around the shop. It has a HF 1300# hoist and the arm is 12' long 2x4" 1/8" wall tube with barn door tracks welded on each side. The tracks are rated for 450# each but 600# is about the heaviest thing I have picked up with it. The trolleys bolt right into the mounting holes on the hoist and are spaced exactly the right amount apart. The post is a double 4x6 that supports the ridge beam and the upper pivot is reinforced with a tension rod that attaches to the 4x12 ridge beam. Seems plenty strong and doesn't deflect much at all under loadCut an MGB and widened 11" C4 Corvette suspension and LT1 Chevrolet power & 6 spd. Pictures here:Part 1http://forum.britishv8.org/read.php?13,7581Part 2http://forum.britishv8.org/read.php?13,22422
Reply:Nice cranes....  I used to do a good bit of overhead crane work in some mobile home plants a few years ago.  Most were in the 6-8 ton range.  I'll see what I can dig up, and take some of my own in the morning..I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:I've got a Budgit 1.5 ton hoist here in the shop. Found it at a yard sale for $20!! This model goes for over a grand new!  I've got to build a boom or a trolley for it, just hanging from a ceiling truss right now!
Reply:Originally Posted by zapster...So...What do you use yo pick up heavy stuff??...
Reply:HAHAHA MAC!actually i was expecting the first wisecrack comment to be a pic of someones arms (flexing of course)
Reply:Here's the one in my shop. No pics of what's under it though, that stall of the shop is a DISASTER right now. -Cory
Reply:Millermatic 211 with 150 spool gunDynasty 350 Hypertherm powermax 30XP
Reply:1 ton, 3 phase electric
Reply:Originally Posted by zapsterWhat do you use yo pick up heavy stuff??
Reply:This is my crane.  Bobcat 773G with all counter weight kits.  And my 2500lbs lifting pole.  I just picked up with dump insert for $1000 brand new.   My buddy was trying to make it a swing. Attached ImagesLincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:It ain't much, but they are mine.
Reply:Well here is my new....errrrrrrrr Old, errrrrr....Soon to be new overhead system.   This is the overhead hoist system my dad built back in the 50's in his farm shop.....  For an old farmer I don't think he did too bad.     After the shop I was renting got sold  I started tearing down the old dilapidated building and purchased an all steel clear span frame to turn this into the new home of "Hammack Welding "  Hopefully one more weekend, and we will have it all torn down and cleaned up so we can start building back....   Anyway here are a few shots..... Attached ImagesI'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:different shot Attached ImagesI'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:I'm not doing to well posting pics tonight............ Attached ImagesI'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:last one..........  can you say OLD chain hoist Attached ImagesI'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:Not exactly a ceiling crane but a crane none the less. Its a crane off of a scrapped Liberty ship that was brought here during the latter part of the WW2 to launch personel carriers. We now use it to pull and step spars on sailing vessels. If you look close at teh 2nd pic you can see our awesome 1 man powered ceiling hoist  Attached Images
GMT+8, 2025-12-21 23:47 , Processed in 0.102316 second(s), 18 queries .
