Will this generator do the job?
发表于 2021-9-1 00:30:13 | 显示全部楼层 |阅读模式
Will this generator power a Lincoln 180, or a Miller 180, and possibly even a Miller 211 running 230V? Found one for sale on Craigs List this morning for $500 with only a 100 hours on it. Add states he is moving this weekend and doesn't have room to take it.http://www.sycamorepro.com/egs-7/Millermatic 251Spectrum 300 PlasmaEverlast PowerTig 250EXEverlast PowerCool W300Harris / Victor OACraftsman 13 Speed Drill PressProTools Air/Hydraulic Bender48" BrakeCompressor, Notchers, Grinders, etc.
Reply:That generator is rated at 6000W continuous which gives you about 25 amps at 240V.The MM180 requires only 21.7 amps at 230V so it should run from the generator easily.The MM211 requires 25 amps at 240V so even running at full power you would only be just pushing the generator's continuous rating.Personally, I think a working 600W generator for $500 is a great deal in general.Visit Tensaiteki.com
Reply:Originally Posted by TensaitekiThat generator is rated at 6000W continuous which gives you about 25 amps at 240V.The MM180 requires only 21.7 amps at 230V so it should run from the generator easily.The MM211 requires 25 amps at 240V so even running at full power you would only be just pushing the generator's continuous rating.Personally, I think a working 600W generator for $500 is a great deal in general.
Reply:Originally Posted by RugarCan you explain to me how its rating says "Total Avail. Amperage 60A"? If 6000W gives you 25 amps @ 240V. The only thing I understand about electricity is how to plug something in and hit the power button.
Reply:Originally Posted by Broccoli1Divide the Watts by the Voltage7200 watts/ 120v = 60ampsbut it is really 2 legs of 120v so 30amps available on each leg- you can't get 60amps from one receptacle.7200watts/ 240v = 30amps
Reply:120/240v Genset breakdownEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
GMT+8, 2025-12-21 23:48 , Processed in 0.091296 second(s), 18 queries .
