Banshee Turbo
发表于 2021-9-1 00:30:07 | 显示全部楼层 |阅读模式
some update pics...I made drag style handlebars to save some weightStrive For Perfection
Reply:Your insane...You know that right?  ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Now I remember why I don't sponsor forums any longer. John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by zapster Your insane...You know that right?  ...zap!
Reply:Let's hope your cheap ebay turbo casing doesn't explode...like most of the others.   I'm so glad I spent all the time helping you only for it to go in one ear and out the other.  You were warned...good luck.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by MicroZoneLet's hope your cheap ebay turbo casing doesn't explode...like most of the others.   I'm so glad I spent all the time helping you only for it to go in one ear and out the other.  You were warned...good luck.
Reply:Very cool setup.  I would assume its an 1/8 mile type deal.  What are you looking to get out of it power and times wise?Lots of toys.
Reply:WOW!!!  That's awesome!!   I had a friend try to turbo his GSXR 600.  Didn't quite work out for him.   Best of luck to you.  I really hope it works out.  I'd like to see a video after its complete.
Reply:That looks dangerous as hell. I am jealous, I want one!!!And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:OK, what is it?I see frame, engine, no axles, no spindles, no wheels, no steering mechanism, no brakes.  What is it supposed to do?Favorite right now is a Miller Syncro 200.Tons of tools and I blame at least one of them when things don't go right.
Reply:Originally Posted by phila.renewalOK, what is it?I see frame, engine, no axles, no spindles, no wheels, no steering mechanism, no brakes.  What is it supposed to do?
Reply:who built the chassis
Reply:Originally Posted by mfurickwho built the chassis
Reply:Originally Posted by elvergonever watch star wars?now he´s just waiting for the anti-gravity mechanism and the turbine...
Reply:Originally Posted by brandon75173Very cool setup.  I would assume its an 1/8 mile type deal.  What are you looking to get out of it power and times wise?
Reply:If you want to see more pics go to the off-topic area look for (turbo??????)Strive For Perfection
Reply:Originally Posted by Brookspower hoping 150+to rear wheel1/8 mile time *** whooping ....haha
Reply:Originally Posted by zapsterI'll race ya with the Mach Z......zap!
Reply:That thing is SICKMillermatic 175 MIGMiller Spectrum 375 PlasmaLincoln AC/DC 225 BuzzboxM-Tech NE5 Tube bender withcustom CNC machined 3/4" think main arms
Reply:Originally Posted by BrooksYea right, whats the HP on that?
Reply:Originally Posted by BrooksIts a garrett turbo have all the paper work...Its not like This is my daily driver to work.. Its for the weekend if that. My buddy has the same turbo running 25lb of boost No problem yet I'm going to run 7lbs...Each is ownThanks for all your help though
Reply:Originally Posted by VipernutCorrection: You are going to START at 7 psi - the boost fairy will be on your shoulder whispering "turn it up, turn it up"
GMT+8, 2025-12-21 23:48 , Processed in 0.088848 second(s), 18 queries .
