The Fun Never Ends...
发表于 2021-9-1 00:30:05 | 显示全部楼层 |阅读模式
I got alot done today...First off was new bushings in a Caterpillar Planetary Drive unit..Unit..Just like before..."Keep it in the groove and don't make a mess out of it"...Had to do all three front and rear..Groove..Kinda down in a hole...Inside of the cover..Yuk..thats gotta go!..Time for the next post.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:All you need is a file and all that yuk "goes away"..Inside weld..Outside..Now lets see whats in store..AHHHHHHHHHHHH!!!!!!!Its another "Johnny slasher knife roller".. I need a break..Next post.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Well I cant put my wheels under this the way it is... Solution is easy enough...Just find a piece of tubing and use that...Worn bearing area..After welding...All done..This is the safest place for this..Back in the box!!!Another day..Another installment of.."I get all the fun jobs!!!"... ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:That's really cool, amazing even. Beautiful work, it still blows my mind that things like that can be done.Miller EconotigCutmaster 38Yes ma'am, that IS a screwdriver in my pocket!
Reply:Wouw, it seems amazing that you could weld in that hole with a TIG torch and be able to see...and get those welds!Is there a secret for this one? My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:Great job, it's about time you did more than one thing at work!  John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by elvergonWouw, it seems amazing that you could weld in that hole with a TIG torch and be able to see...and get those welds!Is there a secret for this one?
Reply:Originally Posted by Joe HThat's really cool, amazing even. Beautiful work, it still blows my mind that things like that can be done.
Reply:Nice work as always...I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:How much time on the lathe do you have for a job like that?Lots of toys.
Reply:Hey ZAP why dont you open your own shop? You've got skills.Miller Syncrowave 200Hobart Handler 140Thermal Dynamics Cutmaster 38E-Z Tube BenderPlasma Cam DHC2
Reply:very nice "Ask not for whom the bone bones, it bones for thee" - Bender
Reply:Originally Posted by brandon75173How much time on the lathe do you have for a job like that?
Reply:Zap , Looks good. I have seen a lot of these rollers been done from you. Whats holding up the other end on the roller when its running on the lathe? Are you using a live center?One other question are you using a four jaw chuck?
Reply:Looks good, I wouldn't want the lathe work though DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:im no weldingt expert but are your welds undercutting a little bit? i am probly wrong but from the pics it looks that way.http://datingsidorsingel.com/
Reply:Whats holding up the other end on the roller when its running on the lathe? Are you using a live center?One other question are you using a four jaw chuck?
Reply:Originally Posted by cheeseclipim no weldingt expert but are your welds undercutting a little bit? i am probly wrong but from the pics it looks that way.
Reply:Undercut is not always a problem.  Especially on a concave weld in a situation like that.  The only stresses on that weld are sheer forces.  If that was on any other pieces where it could be bent or pulled then an undercut would be the thinnest part of the material and that would be the weak point where a crack would start.  The undercutting doesn't make that piece thinner.  The cutting is into material unrelated to the weld.  That make sense at all?Granted a REAL GOOD TIG welder wouldn't cut it anyways.  j/k Zap, your welds are some of the best i've seen.   :P
GMT+8, 2025-12-21 23:47 , Processed in 0.072243 second(s), 18 queries .
