Well, I made a few things...
发表于 2021-9-1 00:29:55 | 显示全部楼层 |阅读模式
First I made some solid mounts for my drag car...Then I made a header for my friends drag car...I am having more fun than ever with my welder I love it...Miller Dynasty 200 DX(love it!, well I did, now its a paperweight)Miller fixed it, haven't used it much yet $2900 warranty Miller 210 Thermal Arc UltraFlex 350Cobra Push-Pull Wire feedLots of other things
Reply:nice work LMG  they both look great
Reply:Verry nice.My Photos on Flickr
Reply:Very interesting....2 quick questions, they are kind of related.1)  How did you bend the pipe?2)  On the rear cylinder, for example, there are two curves welded together to make the transition....why not just bend it as one piece?  I see you did the same thing one the cylinder next to it also.Sorry for the newb question, but I'm curious.Ron
Reply:Nice work!
Reply:Originally Posted by LMGFirst I made some solid mounts for my drag car...
Reply:The mount has two jobs, positioning the engine in the bay, and adding as much support for the block as possible. Thanks for the replies...Miller Dynasty 200 DX(love it!, well I did, now its a paperweight)Miller fixed it, haven't used it much yet $2900 warranty Miller 210 Thermal Arc UltraFlex 350Cobra Push-Pull Wire feedLots of other things
Reply:Originally Posted by chili_uphereVery interesting....2 quick questions, they are kind of related.1)  How did you bend the pipe?2)  On the rear cylinder, for example, there are two curves welded together to make the transition....why not just bend it as one piece?  I see you did the same thing one the cylinder next to it also.Sorry for the newb question, but I'm curious.Ron
Reply:Nice...thanks.But if you really want to impress me, I want to see you weld that brick to the collector
Reply:Originally Posted by chili_uphereNice...thanks.But if you really want to impress me, I want to see you weld that brick to the collector
Reply:Nice work LMG!  What is that in?Hobart 140 Handler w/ gasHyperTherm Powermax 380 Plasmaoxy/acetylene
Reply:The mount is for my mustang, and the turbo header is for a DSM(talon,eclipse AWD)...Miller Dynasty 200 DX(love it!, well I did, now its a paperweight)Miller fixed it, haven't used it much yet $2900 warranty Miller 210 Thermal Arc UltraFlex 350Cobra Push-Pull Wire feedLots of other things
Reply:Originally Posted by 69 chevyNice welds, but I am curious about the design.  Five hexhead fasteners from the fancy bracket into the engine block, but only 1 capscrew from the flat plate to the frame.  Or is that an intentional shear pin?
Reply:Originally Posted by David RIsn't that mount the "down" mount?David
Reply:Nice stuff.. You guys and your turbo's.. Naturally Asperated is the only way.."All throttle NO bottle!!"What do you want from me..I'm "Old Tyme".. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I eat, sleep, and breathe turbos. I do setups for all engines, 4, 6, 8, etc. I can't wait to do my brothers boat, 500+ci, and turbo big turbos...Miller Dynasty 200 DX(love it!, well I did, now its a paperweight)Miller fixed it, haven't used it much yet $2900 warranty Miller 210 Thermal Arc UltraFlex 350Cobra Push-Pull Wire feedLots of other things
Reply:Nice.  I love the welds.  And that turbo is HUGE.  .63 compressor?
Reply:Originally Posted by WelderBoyNice.  I love the welds.  And that turbo is HUGE.  .63 compressor?
Reply:You and Microzone are one in the same..  ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Can a 2 liter engine really generate enough heat and pressure you spool that thing up? That looks like a turbo off of a big rig.Miller Syncrowave 200Hobart Handler 140Thermal Dynamics Cutmaster 38E-Z Tube BenderPlasma Cam DHC2
Reply:they sure can...and we plan on taking it to at least 850hp...AMS's 760 AWHP Automatic 2G Talon, AMS 2.3 w/ GT42R Turbo,  IPT Built Trans and Torque Converter, 4-17-2007Miller Dynasty 200 DX(love it!, well I did, now its a paperweight)Miller fixed it, haven't used it much yet $2900 warranty Miller 210 Thermal Arc UltraFlex 350Cobra Push-Pull Wire feedLots of other things
Reply:If there wasn't so much talent going on there, I'd have to say some serious insanity is involved. However, all I really can say is OMG!Last edited by rat4spd; 08-01-2007 at 12:19 PM.
Reply:Mandrel bent tubing like that is available through summit racing or jegs for any of you guys that want to build stuff like that... may be better suppliers but they are the easiest to deal with....  Have used a few J-bends myself to reroute a tube or two....  Have yet to venture into full custom though.  What thickness wall is that stainless tubing? No support bracket for the turbo?
Reply:Originally Posted by FordBuilderFLMandrel bent tubing like that is available through summit racing or jegs for any of you guys that want to build stuff like that... may be better suppliers but they are the easiest to deal with....  Have used a few J-bends myself to reroute a tube or two....  Have yet to venture into full custom though.  What thickness wall is that stainless tubing? No support bracket for the turbo?
Reply:Sweet! I missed the part about the support bracket.  I was curious as we will be building a turbo setup for our H22-swapped Honda CRX.  Unfortunately I will have nowhere near that much room to work....  Do you make your own flanges or where do you source them, if ya dont mind me askingRacing Solutions sells all kinds of tubing for building headers and exhaust. They also have turbo and header flanges.http://store.racing-solutions.org/index.html
Reply:Originally Posted by FordBuilderFLSweet! I missed the part about the support bracket.  I was curious as we will be building a turbo setup for our H22-swapped Honda CRX.  Unfortunately I will have nowhere near that much room to work....  Do you make your own flanges or where do you source them, if ya dont mind me asking
Reply:Oh as for the flanges check Ebay. I usually have them made unless a customer brings one to me. My personal favorite is to have them cnc'd and mill a shallow pocket to keep everything centered on the flange relative to the port...Miller Dynasty 200 DX(love it!, well I did, now its a paperweight)Miller fixed it, haven't used it much yet $2900 warranty Miller 210 Thermal Arc UltraFlex 350Cobra Push-Pull Wire feedLots of other things
GMT+8, 2025-12-22 01:18 , Processed in 0.093634 second(s), 18 queries .
