Skewed skid caster
发表于 2021-9-1 00:29:53 | 显示全部楼层 |阅读模式
I got to replace a pair of bent swivel casters under a 5th wheel a couple days ago. Time laps photography here, (I gotta take film to get development).The simple fix and the path I chose was to leave the swivel bearings and take off the two side plates on each caster.I needed to keep the wheel height but use nonswiveling skid wheels.Height with the extra steel material will be close enough.With the two wheels ready I tacked them in, adjusted with a screw driver before full weldment.With a spray bottle full of water handy, I immobilized the old caster bases and fully welded the wheels in place. There was still grease in the old caster bearings which constantly caught on fire and lots of fiberglass, wiring and plastic holding up insulation, typical!  Keep the home fires extinguished!! Danny.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Looks good tangle - some nice consistant welds there as well!John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:I appreciate the compliment! Thanx, DannyCity of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:I agree..Nice job.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:You did good.
GMT+8, 2025-12-22 01:17 , Processed in 0.070188 second(s), 18 queries .
