Razor blades welded.....with 7018
发表于 2021-9-1 00:29:46 | 显示全部楼层 |阅读模式
After all the talk of TIG welding razor blades, and many unanswered challenges for someone to stick weld the blades, I decided to give it a shot today. I was just killing time at work and didn't have the ideal rods to do it with, so I used the best we had: 3/32 7018. I set the machine at about 30 amps. Results? Not pretty, but I stuck it together.
Reply:You're right, they are stuck together.  I'd shoot those damn pigeons!
Reply:Lol.I think they were actually seagulls....odd to see them this far north.
Reply:way to go
Reply:Unbelievable...Hold on now ..I mean that in a   way.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:You da welda man!! WOOHOO!!City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Hmm, something new to try when I can get back into the shop. Good work, and I'm officialy accepting your challenge, just give me a little time.
Reply:Looks like you could have used a little more heat and completely vaporized the work. Nice going!    Miller Millermatic 252Miller Syncrowave 200Liincoln AC-DC 225Victor O-A Set
Reply:I bet you could do it with like 1/16" 6013 with a whip and pause at about 15-20 amps.  Who is going to try it first?
Reply:Originally Posted by maxyedor... and I'm officialy accepting your challenge, just give me a little time.
Reply:I'm a little confused about the scale..could you place a dime next to it
Reply:Originally Posted by redfish_joeI'm a little confused about the scale..could you place a dime next to it
Reply:Originally Posted by zapsterRazors are Stainless..
Reply:Originally Posted by WelderBoySo why do my Stanley blades always rust so bad?  I thought they were a hardened steel with a light grease coating to keep them from corroding.  Mine always get rusty in the rain, even in a plastic utility case.
Reply:The Stanley blades are probably a 400 series stainless steel which doesn't usually have the same corrosion resistance of a 300 series and is usually magnetic.
Reply:Lol....Same happens when I leave my car under the tree...at least they are together!My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:I will give welding a couple of blades together with a stick tomorrow.  I think I can do itDisclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:I'm in as well, but think a 1/16" 6013 would be a better rod choice when attempting it.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:hmmm I have been playing with old buzz box out and 7018 rods at home to stay fresh..Think im gonna pick up a set of blades and give this a try.....   Millermatic 175 MIGMiller Spectrum 375 PlasmaLincoln AC/DC 225 BuzzboxM-Tech NE5 Tube bender withcustom CNC machined 3/4" think main arms
Reply:Monkey see? Monkey do!1/16 6013 DCENDavid.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:What can we think of next?...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapster  What can we think of next?
Reply:Originally Posted by WelderBoyStick weld tin foil?  Hmm??  Any takers???  I'll give you an 'atta boy.  Two if it looks nice.
Reply:Originally Posted by David RMonkey see? Monkey do!1/16 6013 DCENDavid.
Reply:Thank you,   Gotta have fun at work even when the work aint so easy.DavidReal world weldin.  When I grow up I want to be a tig weldor.
GMT+8, 2025-12-22 01:18 , Processed in 0.094945 second(s), 18 queries .
