aluminum advice needed
发表于 2021-9-1 00:29:42 | 显示全部楼层 |阅读模式
hello          I have been welding aluminum for about 4 yrs. , mostly castings  but some flat 8 to 12 qauge . I am using gmaw and or puls mode on machine . Any way am able to weld fillets ,buttwelds.  most any position with good results . The problem is with welding   1.5 t0 3"           round tube or pipe in downhand position.Can not get good bead apperance . As far as i know there is nothing wrong with the machine t, tryed different settings, gun angle. What would the aluminum experts out there suggest ?                            Thanks LauranceLast edited by laurance D; 09-16-2009 at 07:53 PM.Reason: title change
Reply:Don't think I'm trying to be a smart @$$ please....I would use tig for that.Otherwise do a nice bevel and be watching the toes widen out and move forward. It's all about the rythym IMO. That is a very fast weld that will take years to master for many folks...some may never make a "pretty" weld there. Just make sure it is 100% Miller Dynasty 700Miller 350P with Aluma-pro push-pullMiller 280 Dynasty with expansion card Dynasty 200 DXMigMax 215 Enuff power and hand tools to create one of anything..... but mass produce nothing!!!
Reply:What is the problem with your bead appearance?  Cold toes, too much build-up, sagging, porosity...?Have we all gone mad?
Reply:Hello        okay this is old thread , Learned alum must be welded hot fast with  aluminum super glaze , What do ya mean TOES:: Never heard of this . Thanks Larry
GMT+8, 2025-12-22 03:09 , Processed in 0.066313 second(s), 18 queries .
