90 Degree Gas Bottle to Regulator Adapter?
发表于 2021-9-1 00:29:42 | 显示全部楼层 |阅读模式
I just picked up a E size bottle of tri-mix gas for mig welding stainless, and found they didn't have any side-outlet bottles available, which is what my regulator suits. So I'm stuck with a top-outlet which means the flow meter is horizontal, so I can't adjust it as the ball just sits there, rather than floating. My question is; is there a 90 degree elbow that can be used to mount the regulator at the correct angle? The flow meter can't be swivelled around, as no matter what position it is in, it remains horizontal. StephMiller Maxstar 200 SDSSC Controls foot controlMig Star 250AL
Reply:i'm not taking the piss here, but if its in a workshop can you tip the bottle on its side? it shouldn't be an issue with argon/CO2 and it might get you out of trouble until you find an adaptor
Reply:it shouldn't be an issue with argon/CO2 ......
Reply:I'm going to tip it on the side if I can't find an elbow, and then set the flow before placing the bottle back upright. I just want the freedom to adjust the gas if need be, and not have to stuff around wasting time doing it. I'm using BOC Stainshield. Thanks for your input,StephMiller Maxstar 200 SDSSC Controls foot controlMig Star 250AL
Reply:Originally Posted by mrmikeyIsn't CO2 a gas over liquid, if so it'll freeze the regulator when it expands going thru it if you happen to draw down the liquid. Or is the low percentage completely gas I'm not sure, hmmmm?.....Mike
Reply:Have you asked your local welding store?  My local welding store always seems to have adapters for anything.  Even if they did not have it in stock, they might be able to order it.Maybe you have more than one local welding store.  I would exhaust that route before I gave up.It is probably possible to get 2000 psi hoses, even if you cannot get a 90 degree fitting.  A  hose with appropriate connectors would also solve your problem, you would just need to secure your regulator to something.I too would be annoyed if I was in your situation.RichardSculptures in copper and other metalshttp://www.fergusonsculpture.comSyncrowave 200 Millermatic 211Readywelder spoolgunHypertherm 600 plasma cutterThermal Arc GMS300 Victor OA torchHomemade Blacksmith propane forge
Reply:...as it's all gas, no liquid....
GMT+8, 2025-12-22 01:18 , Processed in 0.070459 second(s), 18 queries .
