Welding Rod Ovens
发表于 2021-9-1 00:29:31 | 显示全部楼层 |阅读模式
Wondering what the best type of portable welding rod oven is to buy.Gullco seems to be popular here in Canada and is the only brand I have used.I have seen the yellow Phoenix brand around but never got a close look.  Also seen Mathey Dearman, Keen and other brands.Can I get some opinions on what type is and isn't good?Thanks.
Reply:hi, here is a couple of KEENS. The cheap one is what the shop got first and it was ok but then spent  alittle more and got the  K-10. Well worth the 129.00 in my opinionthis the the K-5 http://www.rodovens.com/products/keen-k5-holding.htmthis is the K-10 https://www.rodovens.com/products/k-...lding-oven.htm  more money but more features and better product.
Reply:my advice is to get an oven that will take 18" electrodes. you don't want to be caught out if you need to use bigger sticks on a job
Reply:find an old dorm fridge and wire in a lite bulb  the ins keeps the rods drymiller maxstar 150   hobart handler 210 w mig conversion hobart 250 arc force plasma cutter    boston ind cutting torch miller performance auto darkening helmet milwalkee 14in chop saw 10,000 watt generator huge drill press and industrial band saw
Reply:Just bought the K-15 here: http://rodovens.com/products/k-15-keen-holding-oven.htm
Reply:Phoenix makes a nice one too"Any day above ground is a good day"http://www.farmersamm.com/
Reply:I have a 50lb phoenix and its very nice.  It really holds more like 70lbs of rod if you cram it in there.Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:We have several hundred of the Phoenix type on this project.  The biggest problem with them is the detachable power cords.  Notorious for coming loose/unplugged, so do you have to keep an eye on the indicator lamp.
Reply:A nice feature on small portables is a hanging basket with lift hook.Raising the basket raises the electrodes above the oven's edge, for easy picking with gloved hands.Good Luck
Reply:Originally Posted by MX727Just bought the K-15 here: http://rodovens.com/products/k-15-keen-holding-oven.htm
GMT+8, 2025-12-22 01:35 , Processed in 0.110963 second(s), 18 queries .
