Auto Darkening Hood Question
发表于 2021-9-1 00:29:28 | 显示全部楼层 |阅读模式
I got a Jackson Helmet from my LWS shop last week.I turned the sensitivity all the way up and look at a light and it never switches.There is no on/off button on it, and im a little worried about trying to weld with it.My friend has a High dollar helmet and when i look at a light i can see his switch.What do you guys think?
Reply:Try a different test.  Stand in a doorway between bright sun outside and indoor lighting.  Swing your head/helmet back and forth, facing inside and outside.  On my helmet, with the sensitivity cranked up, it will go dark when I look out the doorway, and lighten up when I turn my head down.RichardSculptures in copper and other metalshttp://www.fergusonsculpture.comSyncrowave 200 Millermatic 211Readywelder spoolgunHypertherm 600 plasma cutterThermal Arc GMS300 Victor OA torchHomemade Blacksmith propane forge
Reply:Did you read all of the instructions? My HF used to switch at a light bulb and so does my new Jackson/Huntsman. If the directions don't help you you might want to call the company. Or you can stand behind someone else welding and slowly peak and see if it changes. (The obvious - don't stare so you get your eyes burnt)"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:You say there is no on/off button.  Is it solar?  May need to sit it out in the sun and get a good charge on it before using it.  I think mine suggested a 4 hour charge in the sunlight after taking out of the box.
Reply:Yeah its solar i left it out for several hours.Going to double check it today.
Reply:An IR TV remote should also make it switch.Matt
Reply:Easiest way to test it is grab a piece of scrap metal, get your grinder and your helmet... put helmet on.. start grinder and look at the sparks.  If the sparks trigger it than you know it works.  This is of course unless your helmet has a grinding mode, in which case that must be turned off.Just my  .02
Reply:try wearing the helmet and sparking a lighter in front of your face, the shower of sparks from the flint should make the lens darken,Lincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE  GUIDANCE OF WISE MEN.
Reply:Model number? My old Lincoln AD you had to press the lens to turn it on. There was nothing on the unit that said this however. All most every good AD will protect your eyes even if off. You may see spots for a bit, but a brief 5 or 6 seconds will not damage your eyes. They are designed that way for when the hood doesn't darken, and lets be honest that happens regularly for any number of reasons. I'm not suggesting you weld that way, only that if you want to strike an arc and be 100% sure it's not going to work, then you will be OK for a brief bit.It isn't something silly like a piece of tape over the sensors is it?.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Best way to know if it will for welding is try welding with it...  Why fool around with cigarette lighters, light bulbs, tv remotes, the sun, etc etc...  Just strike an arc, then there will be no question whether it works or not.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-22 01:33 , Processed in 0.072933 second(s), 18 queries .
