查看: 13|回复: 0
Wood stove pics
发表于 2021-9-1 00:29:27 | 显示全部楼层 |阅读模式
Heres the pics of the wood stove I bought and ash shoot and pan I added. Attached ImagesLast edited by UP BRETT; 02-24-2007 at 02:30 PM.Brett B & B Fabrication and Welding Inc.Spalding, MI.
Reply:Heres the rest. I'll answer any questions I can.Brett Attached ImagesBrett B & B Fabrication and Welding Inc.Spalding, MI.
Reply:Interesting to type the least..How much wood can you put in the box...And how long will it go on a fill-up?...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Looks very unique.DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:its, differen't, but nice, are you heating a garage i guess.
Reply:Originally Posted by UP BRETTHeres the pics of the wood stove I bought and ash shoot and pan I added.
Reply:Graham - nice heat exchanger, how much more heat does it put out? I've seen them at northertool but at $150, they are pricey.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by MicroZoneGraham - nice heat exchanger, how much more heat does it put out? I've seen them at northertool but at $150, they are pricey.
Reply:Zap I can get 3 10" logs in there and then pack it with a bunch of little stuff and get 12 hrs. out of it at nite, with a good pile of coals for the next start. I burn the little and knotty stuff during the day.Graham the heat exchanger is the top of the furnace, if I add a exchanger like yours it would be more effective yet. the tin around the furnace is what dirrects the air flow up and out to the ducts. The blower is mounted in the back at the bottom.Hope this answers the question so far. Any others I'll gladly answer.BrettBrett B & B Fabrication and Welding Inc.Spalding, MI.
Reply:Originally Posted by UP BRETTHeres the rest. I'll answer any questions I can.Brett
GMT+8, 2025-12-22 03:10 , Processed in 0.069134 second(s), 18 queries .
