Generator to welder? Can a regular generator be converted to a welder?
发表于 2021-9-1 00:29:26 | 显示全部楼层 |阅读模式
I have a Coleman Power mate generator which has a 220 volt outlet and two 115 volt outlets on it. And it is a constant duty cycle generator.Is there a add on to make it a welder is my question? I can give more details on the generator tomorrow if there is such an add on.Thanks everyone.  Oh and I'm new been lurking for a while, gotta say you guys and ladies are great and very helpful.Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
Reply:I would imagine with some doing it could be done.  I reckon that available current would be on the small side though.You'd need access to the field circuit, to make the output variable.  And access to the output to rectify it, of course you could use a/c.The other problem I see is the open circuit voltage... 115 volts.  ( You'd want to parallel the outputs to double the current. )  I can't imagine that'd be very safe.Of course to answer your question correctly, YES there is an add-on to make it a welder.  A welder.  Just plug it in.
Reply:Originally Posted by slamdvwOf course to answer your question correctly, YES there is an add-on to make it a welder.  A welder.  Just plug it in.
Reply:Thank you Slamdvw and Dda52.I thought as much. Your input gives me the perfect reason to get a Tig machine,as the wife was the reason for asking. She said you allready have the gas part so get just the welder part.I hope the rest is this easy...Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
Reply:Gotta start somewhere.  Ebay can be your friend when it comes to finding stuff.  If you're not looking to do Aluminum, Miller Maxstars get a great price.  While I'm partial to blue machines, there are others that are just as good, if not better.
Reply:I can think of another way to do it.There is an alternator that a lot of guys in the JEEP world install. It looks to me like a modified chevy style alternator. I suppose you could drive it with a belt off of the generator itself if it was the only load on the motor. I wouldn't imagine trying to use the generator function AND the alternator. But given a choice....I would run a welder plugged into the generator. Unless I was being challenged to be creative.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
GMT+8, 2025-12-22 01:33 , Processed in 0.088035 second(s), 18 queries .
