Getting Ready to Pull the Trigger on a New Welder
发表于 2021-9-1 00:29:23 | 显示全部楼层 |阅读模式
Finally made up my mind that I'm going to buy a TIG welder, it's between a Lincoln 225 TIG and a Miller Syncrowave 200. Both of the welders are on sale now, and very close to the same price.Question I have for you guy's is, witch one, and why?John
Reply:Lincoln, more amps for aluminum.
Reply:red or blue there the best out there
Reply:I know you narrowed it down to between Lincoln and Miller but there might be another to consider.  I would get the one that would have lower amp draw.  It would also have adjustable frequency for Al.  It would be less strain on your back if you ever needed to transport it by being 150 lbs lighter.  So if you have some time take a look at the Thermal Arc Arc Master 185, it may be a little more expensive but your aready in the ball park as far as price is concerned.
Reply:Jay,Who makes this welder?And where can I find info about it?John
Reply:Try https://www.mythermadyne.com/thc/en/...tProductDetail
Reply:http://www.thermalarc.comI didn't do the link right but try going to
GMT+8, 2025-12-22 03:10 , Processed in 0.068849 second(s), 18 queries .
