Welding Solid Steel
发表于 2021-9-1 00:29:22 | 显示全部楼层 |阅读模式
I am about to start a project which mainly involves welds between 1/8"-walled tubular, square steel. However, there is one section (a "T" shape) where the vertical section is tubular but the horizontal section is solid bar (1" square). Is there a special technique to ensure enough penetration into the solid section?
Reply:in general turn up the juice, concentrate the arc on the thicker section and sort of 'wash' the pool onto the thinner stuff. couple of other things to take into consideration- is it a fillet or a butt joint? can you weld it downhand or does it have to be done in situ? how much load and from what direction will it need to resist?
Reply:What kind of machine do you hope to weld it with?*braces for 110v MIG reply*Have we all gone mad?
GMT+8, 2025-12-22 01:32 , Processed in 0.111430 second(s), 18 queries .
